Thread: intex small 8' x30"
    Jun 2012
    VA
    Default intex small 8' x30"
    Yesterday I setup a new 8'x30" pool . After setup I added 1.9 cups of bleach and .4 cup of borax per site calculator using 627 gallons. I ran the filter last night (600 gph) and today CL was bit above 5 and ph was higher than ideal too but off since my CL was above 5. I then added 2.4 oz of stabilizer from walmart (direction said 1 lb for 4,000 gallons) using sock method. In a few days I plan on checking the CYA. I would like expert to chime in on what I should do next.
    thanks
    jason
    Lehigh Valley, PA
    Default Re: intex small 8' x30"
    Welcome to the Pool Forum!
    It's much easier to answer your questions, when we know something about your pool. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    Go swimming
    Keep your chlorine level right for your stabilizer level (see best guess chlorine chart linked in my sig), and drop the pH to 7.0-7.8 range when your chlorine comes back down, and you should be in good shape.
    Jun 2012
    VA
    thanks IZ will let the kids in and monitor the water
  1. New member w/ small Intex pool, looking at salt systems
    By Air_Cooled_Nut in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-21-2013, 07:53 AM
  2. Intex pool "old" stock
    By SafetyBob in forum Intex-type Pool Setup & Operations
    Last Post: 02-22-2013, 11:20 AM
  3. How to properly chlorinate small 12'x30" intex pool? And few other questions.
    By Azmp1 in forum Intex-type Pool Setup & Operations
    Last Post: 07-13-2012, 01:04 AM
  4. small intex 2,000 gallon above ground
    By luvmypool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-21-2012, 11:26 PM
  5. Small "BB" sized hole in my above ground pool wall
    By The Raddish in forum Above-Ground Pool Construction & Repair
    Last Post: 04-19-2006, 12:31 PM
