Thread: AG Pool: How to clean the top rail?
    Jun 2012
    Illinois
    Post AG Pool: How to clean the top rail?
    Just curious, what is everyone using to clean the top rail of the pool. Is there a special cleaner that won't disturb the pool chemistry? Is this something I even need to be concerned with?
    Default Re: AG Pool: How to clean the top rail?
    You can always use a paste of baking soda and water and a sponge--the baking soda is used to raise TA in a pool, but the small amount that might get into the pool should be negligible
    BigDave's Avatar
    I use pool water. I dip a brush in the pool and scrub. It gets it pretty clean, my top rail is painted steel but I also use pool water to clean the skimmer and lid.
  1. Base Rail
    By rplj66 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-24-2012, 03:12 PM
  2. Needing rail-caps forabove-ground pool
    By Jason in forum Above-Ground Pool Construction & Repair
    Last Post: 05-02-2012, 10:41 PM
  3. storing solar cover on rail
    By lsasso in forum Above-Ground Pool Construction & Repair
    Last Post: 08-22-2011, 08:14 PM
  4. Top rail question
    By acmtn in forum Above-Ground Pool Construction & Repair
    Last Post: 05-21-2006, 01:20 PM
