Thread: filter sand whats the best for the money
    Jun 2012
    kansas
    Question filter sand whats the best for the money
    is there a cheap but good sand other than special pool filter sand that one can use?
    Default Re: filter sand whats the best for the money
    I've never heard of anything else. But, do make sure that you do not use play sand that is sold for sand boxes. You do need pool filter sand. It is a little more expensive, but the good news is that you typically don't ever need to replace it. The sand in my filter has been used for the past 12 seasons. Occasionally, you do need to top it off but that's it.
    Welcome to the Pool Forum!
    As far as I know, the only properly graded sand is labeled filter sand.
    There's a sandblast grade that is too coarse. Quartz masonry sand has way too many fine particles. I've seen both used, with a variety of resultant problems.
    Jun 2012
    kansas
    Thanks for the helpful information! Switched to salt last year - this year filtration ! Had heard reference to sandblast & all I found at Box Stores was Masonry sand.
    Jun 2012
    kansas
    Sounds good! Thanks for your help!
  1. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  2. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  5. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
