Thread: Pool wall buckling
    Jun 2012
    West Virginia
    Cool Pool wall buckling
    I have a 24 x 52 round pool that where installing. The walls seem to buckle in at a spot or two while filling with water. Will the pressure from the water force them out when full..T.I.A....Sharkfood
    Default Re: Pool wall buckling
    That seems to be a question answered by our resident pool installer Ted a.k.a. Waste. Hopefully he'll be around later and can offer you some advice. How full is the pool at this point? Can you send some pics to poolforum@gmail.com and reference the URL of this thread?
    Welcome to the Pool Forum!
    I think the common answer has been, if they buckle IN toward the water, you may be in luck. If they buckle OUT, not so much.
  1. Pool Walls Buckling In
    By Ashleybonhoff in forum Above-Ground Pool Construction & Repair
    Last Post: 05-30-2013, 03:02 PM
  2. Foam Wall Liner won't stay attached to pool wall
    By pdxpool in forum Above-Ground Pool Construction & Repair
    Last Post: 07-02-2012, 03:24 PM
  3. NEWBIE - Pool walls buckling while filling
    By wcalasan in forum Above-Ground Pool Construction & Repair
    Last Post: 05-29-2012, 12:43 PM
  4. Esther Williams AGP, wall buckling, cove?
    By jimmymustang06 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-24-2011, 07:55 PM
  5. help --liner rip in winter; pool losing water and walls buckling
    By blondie_30 in forum Above-Ground Pool Construction & Repair
    Last Post: 01-21-2009, 11:36 PM
