Closed Thread
Thread: drain lines
    Fountain, Florida, USA.
    Red face drain lines
    I am having an above ground pool installed soon. The spot that I most want to put it is behind my house about 50 ft. My ? is with my drain lines. The pool would be between the drain lines about 8 ft. from them. I'm in Florida and I don't know if there are any rules about that.Does anyone know? Thanks, Sharon
    Sanford, FL
    Default Re: drain lines
    Do you have a copy of your survey? Mine specifically shows utility easements - from what I understand you cannot have "permenant" structures on an utility easement. That being said - I have two AC units on contrete pads on my utility easement. Check with your local city permitting office or county - just don't give them a name or address, just ask general questions.
    My previous experience is that you don't want them digging into it BEFORE you apply for a permit. I am building a pool now and the sales manager of the PB called the city to inquire as to whether they can install my pool equipment on the side of the house (zero lot line = utility easement down both sides of the house) - as ALL of the other homes on my street have the pool equipment on thier easement. Now the city has contacted the zoning office and found out that our subdevelopment has a zone requirement to keep all side yards open. Then I find out that this wouldn't have even been looked at by the people who permit pools .
    Anyway - keep it vague - also a pool builder should know about local codes.
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
Closed Thread
  1. Air in Lines
    By VickieC24 in forum In-Ground Pool Construction and Repair
    Last Post: 08-22-2008, 08:02 PM
  2. Help! with blowing out the lines using the pump drain plug!
    By Amir in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-06-2007, 05:16 PM
  3. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  4. air in my lines
    By KWBourn in forum Pool Equipment & Operations
    Last Post: 06-24-2006, 08:19 AM
  5. Air in lines
    By VOLDADDY in forum Pool Equipment & Operations
    Last Post: 05-05-2006, 08:35 PM
