Results 1 to 9 of 9
Thread: smell
    Lehigh Valley, PA
    Default Re: smell
    Good job. Did the smell go away?
    Sep 2011
    Default Re: smell
    I was in it yesterday with a scrubber getting the little bit of remaining stuff the rain didn't remove I did not notice any smell. The upper portion of the liner looks much better.
    Forums like this are great tools for DYI'ers! I work on all kinds of things and forums are my first source for info. Often I can find the same situation posted and if I get lucky the solution as well. Its a great time saver.
    Lehigh Valley, PA
    Default Re: smell
    Glad it's resolved.
    Nearly all homeowner pools develop the same problems eventually and you're right, with a little bit of searching you can generally find a solution or at least get some good ideas to try.
  1. Foul Smell
    By elyders in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-17-2012, 12:30 PM
  2. Ozone smell
    By AnnaK in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2010, 01:23 PM
  3. I Smell A Big Anniversaryyyy!
    By tenax in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-04-2007, 09:25 PM
  4. Smell chlorine w/ 0 cc?
    By Madty in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2006, 02:00 AM
  5. Musty Smell...
    By Elias in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-29-2006, 08:29 AM
