Results 1 to 8 of 8
Thread: How often and how long do you backwash a sand filter
    Lehigh Valley, PA
    Default Re: How often and how long do you backwash a sand filter
    When you backwash have a white plastic pitcher handy. At first, the water coming out of the backwash hose will be brownish with lots of tiny bits and particles. After 15 - 20 seconds catch some of the water in the white pitcher and see how it looks. If it's still cloudy, keep it running. Backwashing my filter on a 12,000 gal pool takes about 45 seconds and a lot of water.
    Rinsing packs the sand back down so it doesn't come shooting out of your return when you go back to the filter setting. I rinse for 30 seconds. Be sure you have plenty of water in the pool when you do this.
    Jun 2012
    Kentucky
    It doesn't really have enough pressure to backwash. When I tried backwashing it the water in the clear viewing tube was clear, but the water was coming out very slow. It seems like my filter isn't working. I don't know what is going on.
    Lehigh Valley, PA
    Does your pool have a skimmer basket? It may be full of leaves. And is there a pot with a domed lid attached to your pump? If so, it may also have leaves and will need to be cleaned out.
  1. How often do you backwash a sand filter?
    By tokmom in forum Pool Equipment & Operations
    Last Post: 06-30-2012, 08:52 AM
  2. when to backwash sand filter
    By Kateyru in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 09:16 PM
  3. DE in Sand Filter...how often to backwash?
    By jstkiddn in forum Pool Equipment & Operations
    Last Post: 06-22-2011, 10:00 AM
  4. Sand Filter & DE - backwash to yard
    By vchavez in forum Pool Equipment & Operations
    Last Post: 06-05-2009, 04:12 PM
  5. How do I backwash my sand filter?
    By Kimcoltonterry in forum Above-Ground Pool Construction & Repair
    Last Post: 06-04-2006, 10:25 AM
