Thread: CYA test, optical illussion??
    Default Re: CYA test, optical illussion??
    i did notice the solution was somewhat cloudy so i thhought i would get some reading. and if you have more than one skimmer, would it be faser to disolve if you divided the chemicals you put into them, or when your putting different chemicals? i knew CYA stands for cyranic acid but in another post it made me think any chemical would raise it.
    so what would happen when the dot dissapears, does it cloud up untilll you cant see it, or is it an optical illusion that it gets smaller untill theres nothing left?
    thanks for the info,
    -DoOoms
    The CYA test clouds up until you can't see the dot when you're holding the tube at waist level. I find it helpful to mix the reagent and the water very well, then let it sit on the counter for a couple of minutes while I do my other testing, THEN test for CYA.
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
