Thread: Can't Raise my CYA
    Apr 2011
    Default Can't Raise my CYA
    Hope everyone is doing well! Everything here is fine......but my cya.
    When I first opened the pool it was fine at around 50. I ran out of the drops so I ordered a new large bottle from taylor and am wondering if it was defective. Since testing with the new agent I seem to have zero cya. I've put 2 containers in over a couple weeks and can't raise it. I'm thinking I willl bring a sample to the local pool store for them to check. Any idea's why I can't raise it?
    Cooper
    Default Re: Can't Raise my CYA
    I would get a reading from another source. It sounds like the reagent you got may be no good.
    Let us know what you find.
    [EDIT] I just saw this link in one of BigDave's posts. That kit is worth looking into (and I almost mentioned it, but haven't bought a kit from Wallyworld in ~4 years, so wasn't sure on the price or if they still carried it). [/EDIT]
    Apr 2012
    Texas
    From what I have learned here, whatever CYA you have added this season, it's in there... they usually have a dosage chart on the back of the container. You could do a backwards calculation from that to guesstimate how much cya you have.... I only tested once at opening. Then figured out how many ounces to add to raise mine up to 30ppm, added that, so no need to test it again...as I've been using primarily bleach and a few trichlor tabs in floater that will gradually raise it over the summer. Will only need to test again at closing.
    At any rate, maybe you can get a replacement product from the company if it is defective :/
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
  1. Cannot seem to raise Ph
    By D_Case in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-19-2012, 01:45 PM
  2. No CYA - How to raise it?
    By mortimay in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2011, 06:33 PM
  3. Cant seem to raise TA or PH
    By drbob101 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-11-2010, 11:41 PM
  4. Should I raise my TA now?
    By halefmly in forum DPD-FAS based testing
    Last Post: 02-12-2007, 05:07 AM
  5. Can't raise ph
    By aguaguy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2006, 12:30 AM
