Closed Thread
Thread: No suction when vacuuming
    Mickeymat is offline ** No working email address ** Mickeymat 0
    Question No suction when vacuuming
    I am a new pool owner & am having trouble vacuuming the bottom of the pool. The filter appears to operate properly & I do the backwash & rinse weekly but when I try to vacuum I have very little suction. The hose sucks down to the skimmer but dosen't have enough suction to clean. Thanks.
    Default Re: No suction when vacuuming
    First off -- you really shouldn't have to backwash weekly after the first couple of times to get that first batch of sand and grit out of a newly constructed pool. Just keep an eye on your pressure gauge. When it goes up 8-10 psi over your freshly backwashed pressure, it's time to do it again. Also -- is this a DE filter? If so, are you adding new DE everytime you backwash? Just for comparison, I backwash my DE filter every 2 months, or so. Then, I do the full breakdown and clean at the end of every swim season. So far, mine is operating like a champ.
    As for the vacuum thing -- do you have two or more skimmers? If you do, you'll need to put a tennis ball or coke can over the hole for the one not being used for the vacuum in order to get the suction up.
    My recommendation would be to use an automatic cleaner, like a Polaris 250. I've had my pool for over a year now and have put the vacuum attachment in the darkest corner of my attic, never to be used again. The Polaris does its thing for an hour a day and I never have any worries. I still brush weekly, but could probably stop doing that, too, if I wanted to.
Closed Thread
  1. Loss of Suction when vacuuming
    By handy1 in forum Pool Equipment & Operations
    Last Post: 10-01-2012, 11:10 AM
  2. Poor Skimmer Suction and Good Main drain suction
    By teachone in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2012, 01:06 PM
  3. vacuuming
    By kecsmom in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-19-2007, 11:37 PM
  4. Vacuuming
    By Rangeball in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-22-2006, 08:55 PM
  5. Gradual loss of suction while vacuuming
    By MassAttack in forum Pool Equipment & Operations
    Last Post: 05-12-2006, 08:45 AM
