Thread: New Problem...
    North Barrington, IL, USA.
    Default New Problem...
    My water seems to be circulating but the filters do not seem to be working. My auto pool vac is not working either. How could the pumps be working and the water circulating but the pool vac and the filters not? The filters are not sucking in any water. Basically the water is being circulated, I assume from the drain/exchange in the deep end of the pool. I dont get it?
    Default Re: New Problem...
    Something is blocked or turned off.
    Or your water isn't pumping. Do you feel strong pressure at the return? If not, then the pump isn't getting water.
    It could be as simple as your 6-way valve is not set to "filter".
    I am not sure what the return is but there are two jets in the pool. One has water coming out of it at a decent clip and the other does not. All lines are open and the 6 way valve is set to filter. Could the main filter (the one that looks like a well tank) be clogged/full? Do I need to backwash? Everything was working for a day or so and now it is not. The pool had a lot of leaves in it too. There is no pull whatsoever from the skimmers/filters in the pool. I do not know what to do? Can the motors be damaged?
    All is well. I had quite an education today. Thanks to all. My filter going into my motor was clogged with leaves/worms-big time. Ive emptied it three times in the last 4 hours and the pool has come further in those 4 hours then it has over the last 4 days. Truly amazing. I backwashed as well.
    You might want to try skimmer socks--they fit over the basket in your skimmer, and you'd be AMAZED at what they'll catch before they get to the pump basket!
  1. Please help...never had this problem before
    By Mattcef in forum Dealing with Algae & Slime
    Last Post: 06-19-2012, 07:36 PM
  2. Having a problem we never had before.
    By Hadestech in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-26-2011, 07:24 PM
  3. Algae problem or fliter problem ?
    By ROBIN13 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 02:29 PM
  4. PH and TA problem
    By aguaguy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-27-2006, 02:46 PM
  5. PH problem. Help.
    By bookworm in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2006, 08:18 PM
