Thread: Water temp to add salt?
    Jun 2011
    Default Water temp to add salt?
    Hello all and welcome to a new season of pool fun. This is my first spring start up for my AGP. I have a compu pool SWG. Just wondering what my water temp should be before I add the salt to the pool. I looked at my owners manuel but cannot find this info. Also if my temp is not high enough to add the salt yet what do I do to stop the pool from turning green while it heating. I have no heater at all just a solar blanket. Water is currently clear. Thx.
    AG Pool 15' x 25' x 52" High, Vinyl Liner, 36000 Liters, Hayward Ultra-Pro LX Pump Model SP2290 1 H.P, Hayward Pro Series Sand Filter Model S-210 225lb, Compu Pool SWCG Model CPSC16.
    Default Re: Water temp to add salt?
    I'll let one of the SWCG folks answer the question about water temps, but you can always use bleach for chlorine during times when your SWCG is not working for whatever reason--chlorine is chlorine is chlorine once it's in the pool!
    Virginia
    With my Aquarite, I can add salt at any temp. However, if the water temp is below 60, the unit will only operate at 20% regardless of what level I set it. If the temp goes below 50, then the unit will not operate at all.
    May 2010
    Hi Mr. Mooks, If you would be kind enough to post back with your current Water Temp, I am sure you are o.k. to add your salt now if your water is above 60° F. JimK is right, however, Low water temp can give false measurements if you are relying upon your Controller. My Compupool CPSC24 has an idiot light that tells me that I have low Salt, and that light stays lit almost all winter until the water warms up in the Spring.
    What is your actual Salt Reading? How are you measuring it?
    Jun 2011
    I have no salt level at all yet. They just came and changed my liner and fresh filled the pool. I am more worried about the salt disolving with low water temp. Yesterday the pool temp on the thermometer was 68 F. We had a cool night and even with my solar blanket on it was down to 65F this morning. Sun is out today so hope to get a little heating.
    Don't wait for the salt to dissolve before you get chlorine in the pool--with a fresh fill, you'll have zero CYA, and algae will start up quicker than you can imagine!!
    May 2010
    Quote Originally Posted by Mr.Mooks View Post
    At 68° F You should be good to add your Salt now. Colder temps will affect the efficiency of the SWCG unit, but the Water temp should not impede the salt from dissolving. I agree with Aylad, get some liquid going and add the salt AND THE CYA.
  1. Water temp to Cl correlation
    By scuba in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-05-2011, 07:32 PM
  2. Water temp short
    By tropic in forum Pool Equipment & Operations
    Last Post: 08-24-2007, 03:38 AM
  3. Inaccurate water temp reading
    By GCALAHAN in forum In-Ground Pool Construction and Repair
    Last Post: 03-10-2007, 08:58 PM
  4. Water Temp
    By jcpbnp in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-05-2006, 07:14 PM
  5. water temp already 90 degrees
    By ScottS in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 07:33 PM
