Results 1 to 10 of 14
Thread: Low pH
    Default Low pH
    We have been having problems with our pool for a while and finally seemed to get them under control. But today I tested and it seems our pH is low! I read where you can add Borax to the skimmer to increase it - does anyone know if this is true??? Also, we have a pool cover and a pool heater. I live in FL and the days have been mid 70s lately falling into 60s at night. Though this past weekend it fell into the 40s at night...could my pool cover have an effect on the pH falling?
    In other words...what should I do??? I am having friends over later this week and we'd like to swim but I want to make sure everything is balanced...
    Katy, TX
    Default
    Yes, add borax to raise your pH. Not sure why your pH is low, you didn't really give much information, other than indicate you had a problem. How low is low? How big is your pool? How are you chlorinating? This will help us narrow down the cause of your low pH.
    It's unlikely that a pool cover would impact your pH.
    Michael
    Default
    Bet you use Tri-Chlor pucks to chlorinate your pool. They are VERY acid and drive pH down.
    Otherwise, MW Smith is right. I ONLY use 20 Mule Team Borax (from the grocery store) to raise my pH. I usually add 1/4 box at a time, wait 12-24 hours then test and add again as needed. However, if my pH is SERIOUSLY low (<6.9), I'll dump in a whole box, wait 6 hours, then test again and add if needed. BTW, my pool is 20k and vinyl lined.
    Honesdale PA
    Default
    I think part of the original question dealt with adding borax right in the skimmer. Yes. It will get sucked into the filter and then dissolve rapidly. Within minutes.
    Default
    Yes, I did want to know about putting it in the skimmer - I actually just went out shopping and got some Borax.
    The problems we had were low to no chlorine and the dreaded black algae but we got that under control. We used to have a service, but stopped it b/c the guy wasn't showing up and was saying he did. AND on a weekend we wanted to use the pool it was GREEN. So we figured if it's going to get green it may as well be our fault
    So right now I am in learning mode and VERY glad to have found this forum. I am going to add some Borax to the skimmer - the pH isn't HORRIBLY low but IS low and since I have kids who swim and their friends as well I always want the pool balanced perfectly.
    You could say I've become obsessed with it I guess
    Oh - forgot to say...it is an inground pool, about 15X30 but L shaped - it holds 11,620 gallons. And yes, we use the tabs to chlorinate, we were told they are the best way! Guess I have a lot to learn...what IS the best way to chlorinate if not with the tabs???
    Default Best way to chlorinate
    In my opinion, simply by using plain, unscented household laundry bleach. It is what many of us use. I use it exclusively and always have. In fact, I have never used any pucks at all in my pool nor any other chlorine source at all. Bleach works great, is cheap, readily available. The only downside for some people is carrying the jugs. But, that is not a big deal for me. In my pool, 24ft AG, I typically keep my stabilizer (cya) reading around 30-40 and add approximately 2-3 quarts (not jugs) of bleach per evening. It is easy for me. Takes me about 3-5 minutes per day.
    Watermom
    Default
    Quote Originally Posted by howbout
    The tabs are why your pH is low--they are super-acidic. Stop using them and switch to bleach and the pH should rise without doing anything else. Check your total alkalinity--it should be 90-125. If it's lower add baking soda--start with 1 lb, wait 12-24 hours, and test again. Keep going until it's in range. Since you have a vinyl pool, don't worry about it being too high unless you reach the 190-200 range--then you have to lower it, which is a pain, and explained elsewhere. But anything up to 180 in Total Alkalinity is not a problem--because you have a vinyl pool.
    You also MUST get your CYA level measured--also called Cyanuric Acid, Stabilizer or Conditioner. That determines the minimum level of chlorine you need to maintain--and the max you can use to shock the water.
    Since you've been using pucks, (I guessed right on that, didn't I? ) I'm also guessing your CYA is through the roof--100ppm or more. If so, you will either need to drain off a lot of water and replace it, or maintain very high chlorine levels--8-10ppm normally, and 20-25 to shock. Only practical way to lower CYA is by dilution--draining it off and replacing the water. (there is another way but it's very messy and unpleasant).
    If you have CYA > 100ppm and are trying to maintain chlorine levels in the .5-3ppm range I can guaranteed you are headed for algae central. Pool guys usually mess this up and add tons of chems. Yours didn't--the clown didn't even show up! I suggest you pay him with Monopoly money--you'll stop pretending to pay him when he stops pretending he's working.
    Default
    Quote Originally Posted by CarlD
    Thanks for the info..but we do NOT have a vinyl pool, it's an inground. about 15X30 L shaped...and we fired the guy from the service last year (though that would have been a great idea with the money)
    In any case, since I have added the Borax the levels have been perfect. I check every day...
    Thanks again!
    Default
    You are very welcome. But do yourself a favor and post your water test numbers--it's easier to see what's going on then, but at least, for now, it sounds like things are good.
    Default
    These are from March 18 from yes....the pool store analysis :
    chlorine was 0 - I have obviously fixed that
    ph was 7.8 - that too is now in the normal range according to my test kit
    Acid Demand 1
    Total Alkalinity 80 ppm
    Calcium Hardness 325 ppm
    Stabilizer 50 ppm
    This is all they tested for. We had seen the water "foaming" and were told to next time ask for a TDS test. I am not sure we will be going back there next time so...the ranges they gave for the above were all fine for what we need (according to their analysis) except the pH was then high and of course there was no chlorine...
    So any suggestions at this point? The pool is testing fine for both chlorine and pH now (my own test kit) but that is all I CAN test for. The water is crystal clear...
