Results 1 to 10 of 12
Thread: How often do you backwash a sand filter?
    May 2012
    WA
    Default Re: How often do you backwash a sand filter?
    Thanks. I did not think it would hurt to turn off the pump on the cooler days if the heat pump isn't running. Our weather is so iffy right now. We can have 3 days of warm weather and then a week of cool (60's) and rain. I can't think of a reason to run the darn thing if we won't be swimming for a week.
    The pool store said to run it 24/7 during the summer, so that is what we have been doing. I'm worried we will over work the poor thing!
    doughboy 24x24 AG round 16,100 gal with 3.5 and 6.5 deep end. Doughboy sand filter. Doughboy 1 hp pump. Tropi-cal 75k btu heat pump.
    It is not necessary to run it 24/7 unless you are trying to clear up a water problem. Otherwise, it is just wasting a lot of electricity. But, you really should run it some each day. A pool with no circulation for a week is more prone to an algae bloom.
    May 2012
    WA
    Good to know, thanks! We have some warm weather coming up (for us anyway, mid 70's, lol) so we will run the filter/pump so we can heat our pool back up. We typically drop it down to mid 70's when we aren't swimming and a few days prior we turn up the degrees to heat the pool. From now on we will run it daily for 10 hrs or so and then turn it off.
    10 hours per day should be just fine.
    May 2012
    WA
    Got it. Thanks.
    I have a two-speed pump and I run it on low for 12 hours a day. On high, less, but I rarely use high speed.
  1. How often and how long do you backwash a sand filter
    By missparker205 in forum Pool Equipment & Operations
    Last Post: 06-04-2012, 02:17 PM
  2. when to backwash sand filter
    By Kateyru in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 10:16 PM
  3. DE in Sand Filter...how often to backwash?
    By jstkiddn in forum Pool Equipment & Operations
    Last Post: 06-22-2011, 11:00 AM
  4. Sand Filter & DE - backwash to yard
    By vchavez in forum Pool Equipment & Operations
    Last Post: 06-05-2009, 05:12 PM
  5. How do I backwash my sand filter?
    By Kimcoltonterry in forum Above-Ground Pool Construction & Repair
    Last Post: 06-04-2006, 11:25 AM
