You said you have a Minimax heater. I also have a Minimax (propane) heater. There is no incoming power on this type of heater. The way it works (at least my Jandy/Laars unit) is the gas pilot stays lit all the time. The pilot heats up a device that creates the small voltage which is needed to allow the gas valve to open. If the pilot light ever goes out or the voltage generator doesn't work the large gas valve will never open and no heat. In addition to the voltage generator safety device you need continuity through the water pressure switch, a fusible link, high temp cutout switch, the on/off switch, and the adjustable thermostat. If you have the type heater I am describing you can test the entire circuit with a Volt-Ohm meter.
Can you provide the specific make and model of the heater?
