BigDave,
Thanks for the reply! I'll remember to use the smaller sample next time I'm testing the chlorine.
I am going to spend some time this evening studying Ben's Best Guess Chart. I will also do the bucket test on the pool water as I only did it on the hose water that was used to fill the pool. I'll report back with those results in a day or so.
In the mean time, to answer your question my chlorination has been from the chlorinator-thing that was installed on the pool pump (I'm so ignorant, my apologies) as well as some shock after the rains (and when the chlorine level is low). Do some people only supply chlorine to their pool via shock and just dumping it in?
As foreign as this all is to me, I am wondering if the brown stains aren't from algae as well. If it is algae, would the stains be able to be lifted once I get the levels under control?
Until I report back w/ the results of the pool water bucket test....
MUCH GRATITUDE!
Amy
