Thread: How long does it take to adjust the pH
    May 2012
    North Carolina
    Default How long does it take to adjust the pH
    Well we are a few days away from having a hole in red clay to having a pool.
    Quick question - we are having water delivered - I have a private well and do not want to drain 10k gallons from it - generally how long does it take to get the water ph etc correct? We are doing a salt water pool.
    Thanks,
    Lance
    Default Re: Newbie here - first post
    Not long. Do yourself a favor and go ahead and order a good test kit. Get the Taylor K-2006 or 2006C from the testkit link in my signature below. That way you'll have it ready to use when you get your pool. Is this an above ground pool? If so, are you aware that having as SWCG on an above ground pool generally voids the warranty?
    Welcome to the Pool Forum!
    It doesn't take long, if you know what you're doing. You'll need a reliable set of test results (drop-based kit, please--no strips!!) so that you know where you're starting from. You will definitely need salt and CYA, and a good test kit (see the link in my sig). You'll also need some plain, unscented bleach, or chlorine granules to chlorinate with while you get your chemistry straight. Besides that, you use Borax to raise pH and baking soda to raise TA if you need to, but we won't know that until you run a set of tests on your water.
    Welcome to the forum!!
    May 2012
    North Carolina
    Thanks....it is not above ground just a not very big inground
    member status upgraded --
  1. How to adjust CYA down
    By l8nite4me in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2007, 04:27 PM
  2. How to Adjust pH and TA
    By iwannapool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2007, 05:22 PM
  3. What should I adjust ?
    By aswetich in forum DPD-FAS based testing
    Last Post: 07-27-2006, 07:33 PM
  4. Adjust TA first, right?
    By jnorris in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2006, 11:07 AM
  5. Which one should I adjust first
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 01:32 PM
