Steps so far the recap:
Removed ozone line and plugged with OEM plug per suggestion.
Impeller, seal, wear ring, replaced, though clearly unneeded (i already ordered before talking to the experienced folks on here)
The basket side has no visible cracks, etc.
removed motor from pump and it is quiet as a mouse when left running without a load
The main symptom is in a matter of seconds it starts making the racket like cavitation and the pressure drops at the filter.
On the suction side is two skimmers and a double drain.
On the pressure side is filer, chlorine feeder, split off to a return valve and a water feature valve.
The last things done prior to this occurring though this did not start when these maintenance items were performed
Filters pulled and cleaned
Valve to water feature replaced
Thanks All. At some point I guess i will be calling service, the fam will only wait do long on my shenanigans....
