Results 1 to 10 of 11
Thread: AquaRite installation: how hard is it?
    Tucson, AZ, USA.
    Default Re: AquaRite installation: how hard is it?
    Quote Originally Posted by mrmrk49
    Wiring the SWG controls to the same (timer-controlled) AC line as the pump doesn't sound like a good idea to me: pumps are 'noisy', I suspect they have large surge currents like an air conditioner (not really sure though), and would likely produce voltage spikes when turned off.
    All of these are bad for integrated circuits and transistors; any voltage spikes on the ground line during turn-off can easily blow most ICs
    I know that Hayward also recommends wiring to the pumps AC supply, not really sure why since I think they still have a flow sensor anyway.
    Comments on pump spikes/noise/etc welcome, as I am not really sure how bad the problem is. I know that a light bulb on the washing machine circuit really flucuates with the wash cycle
    Maybe I'll hook up a light bulb to my pump power and try a few on-off cycles .
    My old SWG is a Pure&Clear model, with the cell actually in the pool; it was installed using a GFI receptacle. I guess cells that mount in line don't need GFI protection
    Mike K
    I'm not sure wiring it any differently would make THAT much of a difference...Even with my (expensive) Polaris EOS the power all comes from one big fuse block fed by the same 230 volt input, so any big surges from the pump are likely to affect the whole system...
    I have basically the same question about my install. My pool is an older setup as well (now being modernized in equipment at least with a Polaris EOS and my new Waterco 2 speed pump sitting on the pad waiting for me to install it once I get my 2 speed relay)..I've been debating installing a SWG (the Polaris Auto Plus of course, since it wires right into my wireless controller)...They recommend 22 inches straight pipe to wire it in to the plumbing AFTER the heater, but I have at most 12 inches from heater to dive into the ground.
    Polaris also shows an install with a bypass manifold of sorts, basically splitting off flow and running part of the flow straight through a check valve and the bypass holding the SWG cell..
    Anyone else install this way? It would sure make my plumbing easier for the cell (I could even put it after the 3 way valve for the spa on the pool return if I wanted then (which also has very little spare room))
    Comments?
    Sacramento, CA
    Quote Originally Posted by cschmelz
    Comments?
    Good point about using the same AC supply, my system has a ganged 30A at the main breaker box. that supplies pump and lights and SWG (seperate CBs in the control box though).
    I'm not sure whether having the SWG already powered up when the pump turns on would be better or worse under these conditions.
    I still think it is bad to have SWG and pump on same AC line, but running an extra AC line would be expensive - running it in same conduit as the pump would mean derating the wires for both, i.e., using larger than normal wire sizes
    MikeK
    Ft Lauderdale, Fl
    Salt Water Chlorinators consume very little amp draw on a circuit and is recommend to be tied into the same pump relay or terminals. AutoPilot for one, has been installing salt systems integrated with the pump circuit for over 12 years. The only time we recommend a direct connection to the circuit breaker is if you are using the unit to control a circulation pump.
    While there is a flow switch to protect and turn the swc off when there is insufficient flow, its a better precaution to not have to rely on it all the time. IF you were to have a failure that indicates that there is flow and the cell gets energized (with the pump off), you're sure to accumulate dangerous hydrogen gases.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    I just completed a new pool install in March this year that included among other things an SWG. I had the ground leveled, pool frame & liner installed but I completed the plumbing, deck, fencing, landscaping and electrical installation.
    If you can glue and measure PVC piping the plumbing is no big deal. The Aquarite had directional arrows telling you which way the water should flow thru the cell and flow switch.
    The Electrical is more important. There are strict pool wiring codes provided by the NEC. It's important that the entire system be grounded and bonded. I used THWN/THHN wire for all of my 4 circuits. All are protected by GFCI breakers. There is a separate ground rod at the pump house and a bonding loop that connects, pump motor, pool frame, deck & Aquarite.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
  1. aquarite swg
    By pc boy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2006, 03:46 PM
  2. What's better than Aquarite?
    By jacksonlui in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 11:35 PM
  3. CYA and Aquarite
    By bethsg in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-08-2006, 09:54 PM
  4. CYA and aquarite
    By mizzouguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-22-2006, 09:38 PM
