Results 1 to 10 of 12
Thread: Test Results and Chlorine questions
    Apr 2012
    Illinois
    Default Re: Test Results and Chlorine questions
    Just tested again this morning and my alkalinity is now 80 ppm. I tested it 3x because i couldn't believe it. I swear it was 200 for the past two days as i tested it multiple times. Not sure what would bring that drop but i'm happy as i was not looking forward to using muriatic acid.
    Good. TA of 80 is just fine. How does the water look now? You do NOT need to raise your calcium level.
    Do us a favor and put your pool specs in a signature line. (Use the link in my signature to make one for yourself.) Put type of pool, volume, type of filter, size of pump, any equipment you have and whether or not you have a Taylor K-2006 kit. It makes it easier for us to help if we don't have to scroll up looking for information in a thread.
  1. Test results and questions
    By Jeffski in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2009, 12:14 PM
  2. 1st test results of spring - few questions...
    By court475 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2009, 01:37 PM
  3. A couple of questions about 1st test results
    By BogeyGolfer in forum DPD-FAS based testing
    Last Post: 07-15-2006, 06:24 PM
  4. test results and SWG questions
    By poolbee in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 12:27 PM
  5. Test Results questions
    By DaveInPA in forum DPD-FAS based testing
    Last Post: 05-30-2006, 10:50 PM
