Results 1 to 10 of 14
Thread: New Pool
    May 2012
    South Carolina
    Default Re: New Pool
    I added about 1lb of Sodium Carbonate (pH up) yesterday. Then it rained a ton.
    The feeder is NOT on, and the tablets (3" trichloro-s-triazinetrione tablets) are still in the car, lol.
    Chlorine dropped to 6ppm.
    pH is 7.6 now after adding and waiting approx. 24hrs to retest.
    I have no Combined Chlorine reading still. Is that a problem?
    looking good i think.
    You don't WANT a CC reading, or rather, a reading of CC=0 is optimal. So, no, it's not a problem.
    BigDave's Avatar
    You need a source of chlorine. If you don't maintain chlorine, your pool will go green again. You can use tabs in your feeder for a while but when your CYA reaches 40-50, it would be best to stop the stabilized chlorine and start using bleach.
