Results 1 to 10 of 80
Thread: Cannot Get Rid of Cloudy Water
    Lehigh Valley, PA
    Default Re: Cannot Get Rid of Cloudy Water
    None of us do
    Just scoop them out with the leaf net and set them somewhere where you know you won't spill bleach on them. Given your CYA of 70 you don't really want to use them anyway because they keep adding more CYA and dropping the pH. Put them in an bucket with a lid. They'll keep.
    Once they're out of the way you can go ahead and add the bleach.
    ajb8898 is offline Subscriber Thread Analyst ajb8898 0
    May 2012
    South Carolina
    OK I will do this tonight. Thank you so much for the help so far.
    Lehigh Valley, PA
    Happy to help. Remember to look for filter socks as they'll really improve the filtration. I suspect we'll have a clear pool for your Memorial Day activities. If you're out and about shopping you might pick up a box of 20 Mule Team Borax. We may want that to raise the pH in a couple of days. It should be in the laundry aisle of your grocery store or at Walmart. If you can't find any, see if they have Washing Soda. Washing Soda will also raise the TA (alk) but we could live with a small increase.
    May 2012
    South Carolina
    OK, kids got in to swim this evening, cloudy water and all. They said the bottom felt clean. I then added 2 gallons of bleach and then brushed the bottom to be sure it was all stirred up. Walmart was out of Borax so I got the Washing Soda instead. I also got Baking Soda just in case. They also did not have any filter socks but I will get some.
    I'll report more in the morning.
    15K gal AG oval w/ Hayward sand filter; Taylor K2006C
    15'x30' oval 15K gal AG pool; bleach; Hayward sand filter; Hayward pump; 24hrs; Taylor K2006C; utility water; summer: ; winter: ; iPhone; PF:8
    Lehigh Valley, PA
    Kids!
    Did you add 2 gallons? Or 2 jugs? A gallon is 128 oz and we were shooting for 126 oz. You'll have a goodly amount of chlorine to kill whatever might need killing. If you have the chance to take another water sample to the pool store for testing let's see what the pH is. Some pH tests fail when the FC is over 10 ppm. I'm not entirely comfortable recommending how much washing soda to add until we have a reliable pH number.
    May 2012
    South Carolina
    Sorry, I didn't say that right. I bought the 184oz bottle at Walmart and my husband did his best to add 2/3 of it so we could get around 120oz.
    I would advise you to go ahead and put those partially dissolved trichlor tabs back into the pool and let them dissolve. That way you don't have to worry about how to store them. But, then, just don't use any more. (They won't add that much more CYA to make much difference at this point.)
    Lehigh Valley, PA
    Quote Originally Posted by ajb8898 View Post
    Thank you for the clarification.
    I use a wide-mouth plastic bottle with a screw cap; it holds 86 oz (I think) and has increments of 16 oz marked on it. I pour chlorine from the bleach bottle into the measuring jar. I've also used a plastic 1 qt measuring cup in the past. Most of my bleach additions are in the 16 oz range so being able to measure the smaller quantities is handy.
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 07:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 12:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 10:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 02:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 08:04 PM
