New Pool Owner - Newbie at testing water - Need Some Guidance
					I just had a new pool installed before the winter. Opened up the pool and was surprised on how clear the water was, aside from some fine dirt particles that came through a mesh winter/safety cover, which is used only during the winter due to the amount of snow we typically get in Ohio.
I purchased te recommended Taylor test kit K2006C and the Taylor K-1766 (salt test kit)
I am following the BBB methodology. I added 6 gals of bleach a week ago. Auto cover was on, pump circulating. When uncovered, water is slightly cloudy.
Initial test results:
FC = 2.0 PPM
CC = 0.5 PPM
PH = 7.0 - 7.2
Alk = 120 PPM
Calium Hard = 130 PPM
Cyanuric Acid = 0 PPM
Salt = 2,800 PPM
I know that my stabalizer is non existent. However, I am confused, as I thought I did not have to added any additional chemicals other than BBB. I know it should be in the range of 30-50 PPM. Is that my problem to cure the cloudy water? From reading other post, I know there is granular and liquid versions. Do I need to purchase this as well in addition to the BBB method? If so, what is the best way to apply it and how much.
Any help anyone can provide would be helpful.
Thanks.
			IGVL 22'x40' 33,000 gals w/ Autocover
~Pentair Mechanicals~
Pump: Intelliflo VF
Filter: Triton TR60 w/ ClearPro technology
SWCG: IC40
Heat Pump: UltraTemp 120 Heating & Cooling 125,000/75,000 BTU (Primary)
Heater: 400 BTU Mastertemp (Secondary)
Controls: EasyTouch 8 Ch. w/ load center and built in IC40
