I have a 12,500 gal inground vinyl pool with sand filter, just opened 3 days ago. A little dirty at first, but looks great now except for some algae on the liner above the water line that I am gradually toothbrushing away. CYA level was zero at opening, so I added 2 lbs of CYA in a sock which just finished dissolving this afternoon. Checking the chlorine level three times daily, I either get 1 or 0. Each test is followed by adding 1.3 gal of 6% chlorine (total of about 15 gallons so far). TA is 100. pH has dropped from 7.4 to 7.0 over the past several days. I would like to raise the pH with Borax. Is there an equation (or expert advice) to determine how much Borax gives how much pH rise per 10,000 gallons at a given TA? Does the stuff dissolve easily, like baking soda, or do I need to get out the CYA sock again?
Thanks in advance.
Searched the site for this issue without success; I apologize if it has already been discussed elsewhere.
