Thread: Spider Gasket
    markphin is offline Registered+ Thread Analyst markphin 1 star
    Default Spider Gasket
    Hello
    Well I know that I need a new spider gasket for my multi port valve(Purex Triton, model SM20-2). I ordered a new one from pool store. Problem is though, it seem a bit smaller in diameter than what's in place now. The pool store insists its the right one. My question is, are you expected to stretch these a bit to fit in place or should it fit perfectly w/o stretching it. I don't want to remove the old one till I'm sure I have the right one
    Thanks in advance for any insights
    Default Re: Spider Gasket
    You shouldn't have to, nor should you, stretch the spider gasket to make it fit!
    The spider gasket they sold you is not the correct one for your multiport.
    Thanks Ted. I thought that was strange. I called Pentair and managed to get the manufacturer number for the gasket and ordered at an on line pool psrts store that actually had reference to that part number. So hopefully that'll be the ticket, at which time i'll go back to the pool store to show them thay are wrong.
    Thanks for the help
  1. Spider gasket adhesive question
    By keljoh in forum Pool Equipment & Operations
    Last Post: 08-16-2012, 05:32 PM
  2. Need a Hayward spider gasket
    By Bkirrane in forum Pool Equipment & Operations
    Last Post: 05-28-2012, 10:30 AM
  3. Hayward spider gasket replacement
    By briel in forum Pool Equipment & Operations
    Last Post: 05-24-2012, 10:20 AM
  4. Spider Gasket - First Obsticle
    By Sprint54 in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2006, 10:31 AM
  5. Replacing Spider Gasket
    By let_her_flicker in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 11:49 AM
