Thread: fiberglass pool issues need advice
    May 2012
    florida
    Default fiberglass pool issues need advice
    hello all newbe on the forum
    recently I have purchased one of those forecloser homes in south florida to live in. The house is good and the pool
    is a disaster. Let me start with that when I signed contract for house the pool was drained which they do a lot over here when the house is abandoned. So when I got the house the pool was filled and not running . Also noticed that every single day the water level is dropping about 2 inches . when pump was running it dropped about a feet in an hour . after taking a closer look and some research I have find out that this is a fiberglass pool made by gold key pools
    so here is what my suprise was the pool is finished with diamond brite and is cracking everywhere. so I got myself a small jack hammer and cleaned close to half all diamondbrite. it is a lot of work. after that I plan to sand all surface and put a layer of fiberglass and then gelcoat. I still have not find where the leak is , water level already past returns and light but it is still dropping so I would say it must be the main drain but when pump was running that would suggest it is in the return line . I have find some pictures from the seventies that looks like my pool .
    the company went out of business in early nineies . I will post some pictures where I am in progress but in the mean time if you all have any advice or thaughts it is greatly appreciated. please exuse my english I can speak better then write
    Default Re: fiberglass pool issues need advice
    Send your pics to poolforum@gmail.com, and make sure to reference this thread so that he knows where to put them....
    Welcome to the forum!
  1. Newbie with pool chemistry issues
    By pool2012 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2012, 11:09 AM
  2. Stone coping advice on a new fiberglass pool.
    By krdowns in forum In-Ground Pool Construction and Repair
    Last Post: 07-06-2012, 11:25 PM
  3. Opening Pool issues
    By wolvskiss in forum Pool Chemistry for Intex-type Pools
    Last Post: 03-26-2012, 06:33 PM
  4. Help! Pool Cover Issues and Leak Issues
    By b2001 in forum Pool Equipment & Operations
    Last Post: 02-17-2008, 05:34 PM
  5. Issues with Pool
    By SPitz in forum In-Ground Pool Construction and Repair
    Last Post: 03-29-2007, 11:31 AM
