I am having an especially difficult time with algae this year. I have a 24000 gallon inground vinyl liner, sand filter, 3/4 HP pump. When I took the cover off, water was dark green and cloudy. Usually lots of shock clears it up in about a week, but after 3 weeks I'm still dealing with light green cloudy water. Here's what I've used so far:
1. an entire 40 lb bucket of granular shock
2. 15 lbs of alkalinity up followed by 30 lbs of soda ash to get ph to 8.0 so I could use "green to clean" (had good results in the past)
3. 1 container "green to clean" with 8 lbs shock, followed by another 6 lbs shock 12 hours later
4. 1 bottle "pool magic" to eat up the dead algae (no results)
5. changed out sand in filter
6. 10 lbs power powder
7. running pump 24/7 on "recirculate" (before today i was filtering)
here's what my tests show (pretty consistent for the past few days)
TC >10
FC >10
ph - between 7.8 and 8.0
TA 180
CYA 150
any advice? i've removed as many leaves as i can with my "blue devil" but who knows what's down there since i can't see the floor of the pool. also brushing daily. just give it more patience? i'd be tempted to drain and start over, but my main drain doesn't work and draining is a nightmare! i know my circulation is a problem without main drain, but i've been circulating through the skimmer only for 5 years, never had this much trouble before.
(i used just shock, yellow out and chlorine tablets)
