Results 1 to 9 of 9
Thread: Eyeball looks where?
    Default Eyeball looks where?
    Where do you point the return eyeball in a round AGP? The installers point it straight out, and someone else suggested straight down. Someone else mentioned down and counterclockwise. What do YOU do? And why, please?
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Default Re: Eyeball looks where?
    I point mine downward and to the right, to make the water circulate around the pool,
    It also moves the dirt to the center of the pool for easy vacuuming.
    JJ in Tx is offline ** No working email address ** JJ in Tx 0
    Spring, Texas
    mine is angled down and away from the skimmer opening
    for exactly the reasons haze said "make the water circulate around the pool,
    It also moves the dirt to the center of the pool for easy vacuuming."
    JJ
    ditto......
    Newbie65 is offline ** No working email address ** Newbie65 0
    Smile Re: Eyeball looks where?
    What if you have two on opposite sides of the pool? Point both of them down and counter clockwise?
    33 round ABG
    Spring, Texas
    yes!
    you want them pointing in the same direction so they are working together not against one another.
    JJ
    Thanks for replies. All of you down-and-to-the-right pointers: don't you find that the whirlpooling water makes the debris on the surface sail past the skimmer, though?
    Spring, Texas
    no problems with the eyeball aimed that way, my skimmer still catches lots of stuff, and the fine stuff to vac out is all right in the middle.
    JJ
  1. Aiming the eyeball
    By RobDHW in forum Pool Equipment & Operations
    Last Post: 05-22-2012, 10:26 PM
  2. Replacing eyeball returns
    By schristi69 in forum Pool Equipment & Operations
    Last Post: 06-14-2011, 10:46 PM
  3. go pens- eyeball angle
    By go pens in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-04-2011, 11:40 PM
  4. Eyeball direction?
    By abessellieu in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 12:54 PM
  5. Eyeball return direction???
    By pool newby in forum Above-Ground Pool Construction & Repair
    Last Post: 07-26-2006, 05:56 PM
