Hi all, opened this spring and had lots of water under the IG vinyl liner. Managed to get the water out by using the pool pump and vac line (actually worked quite well). But now I still have the liner pulled out at all corners along the bead, one of which is out for several feet. I saw a hair dryer post, which I will try. Also a re-floating idea. But I suspect these are not going to get me anywhere near the amount of slack I need.
Has anyone ever heard or tried a carpet stretcher to try and work the liner back in an inch or two at a time?
Any other ideas?
Chuck
