Results 1 to 10 of 15
Thread: Help-Pool Guy Is A No Show
    North Barrington, IL, USA.
    Default Re: Help-Pool Guy Is A No Show
    Thanks, unfortunately the leaves are all in the deep end of the pool. Ill work on it. One more question, is it OK to turn the heater on right now or do I need to wait for some reason? I thought I read somewhere that I should wait. Thanks.
    docsobeck is offline PF Supporter Thread Analyst docsobeck 0
    there's an inexpensive item that's GREAT for getting out all those leaves in the bottom without vacuuming and clogging up the baskets repeatedly. check it out here:
    http://www.shopping.com/xPC-Big_Sucker_Leaf_Vacuum
    there are a couple of brands available. you can find these at most pool stores, and even some wal mart-type places, or home centers. i've seen them for as low as $21, and it works great for leaves. just attach to your plain old garden hose and telescoping pole, then drop it in and suck up the leaves. the only down side is that is stirs up the dust on the bottom and clouds up the water a bit, but that's why you have a filter.
    Katy, TX
    I'd wait to turn on the heater until you check your water balance. That becomes very important when heating, because if not correct, it can damage your heat exchanger.
    Michael
  1. Show me your AG pool deck railing please?
    By seminolewind in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2007, 08:20 PM
  2. Spinoff: Show me your deck storage boxes
    Last Post: 06-06-2007, 08:05 PM
