Results 1 to 8 of 8
Thread: First Post and low stabilizer..
    May 2012
    South Carolina
    Default First Post and low stabilizer..
    I have a 27 ft above ground pool and I have drained it to clean in and refilled recently. I want to make sure I get started out right. I have had my water tested and I have tested myself and so far this is what I got. PH around 7.2 to 7.4. Total Alk is 60. No Stabilizer. My question is whats best to use to raise the stabilizer? Thanks
    Default Re: First Post and low stabilizer..
    You can either add straight stabilizer (sold as balancer, conditioner, but the ingredient on the label is cyanuric or isocyanuric acid), or you can use trichlor tabs (which will raise chlorine, lower pH, and add stabilizer) or use dichlor powder (which will raise chlorine, lower pH, and add stabilizer faster than trichlor will). Just depends on what you have on hand and what you prefer.
    Welcome to the group!!
    Since you have none, I'd go with either dichlor or just adding CYA outright. Waiting for the trichlor pucks to dissolve will add the stabilizer more slowly and in the meantime, you'll have to be adding chlorine really often which will be a big pain in the rear. Just my $0.2. Welcome!
    May 2012
    South Carolina
    Thanks I did buy some conditioner. It was a small container and I added half of it but didnt seem to make the stabilizer rise any. It said dilute in warm water then poor in skimmer. It came in a crystal form and I put it in a bucket of warm water and stirred it up but it didnt dilute much. I added it to the skimmer any how. It also said it may take up to 72 hours for it to dissolve. Does this sound about right. Should I wait till I add the second half of the container. I beleive it was a one pound bucket of conditioner. Thanks and I have really enjoyed reading all the posts and great information.
    27 ft AG pool -- ~16K gal => PF 7
    Yes, it can take 72 hours--or longer. We usually don't recommend that people re-test for CYA, or add more, until at least 4-5 days when adding CYA. If you have a sand filter, you also need to not backwash it until the CYA has fully dissolved. If you backwash, you'll just wash out the undissolved CYA on the filter and have to start over again.
    Lehigh Valley, PA
    There is a liquid form of stabilizer available, pricey, but if you're in a hurry it might be the thing for you.
    My ballpark guess is you'll need 3-5 pounds of CYA to get a decent stabilizer level. You CAN use the tri-chlor pucks. They do have one advantage in that they can help keep a fairly consistent level of chlorine in the pool while slowly adding the CYA. For every 1 ppm of FC added, .6 ppm of CYA is added.
    May 2012
    South Carolina
    Ok thanks im going to add the half of the crystal form of conditioner I have left and recheck cya in a week or so then start with the pucks till the cya level is right. Thanks for the help.
  1. stabilizer
    By unklebuk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-03-2012, 04:51 PM
  2. Stabilizer?
    By Mr.Mooks in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2011, 08:40 PM
  3. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  4. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
  5. cya 0 after nearly 3 1/2 lbs. stabilizer
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2006, 01:53 PM
