Results 1 to 10 of 11
Thread: Can't get pump lid open
    Jacob99 is offline Subscriber Thread Analyst Jacob99 0
    Aug 2011
    Massachusetts
    Default Re: Can't get pump lid open
    Thanks. Yea, I'm the one who overtightened it because it was leaking so I figured it wasn't tight enough. It shouldn't be worn because it's brand new, but maybe I damaged the gasket by tightening it so hard. The 2x4 probably won't work as the handle is made to grip underneath with your fingers.
    Loosen it slightly while pump is running goes against everything I've previously heard, but may be my only option. I'll be sure to keep my face clear of it's path in case I loosen it more than slightly by mistake.
    Wilbar/Sharkline Tahitian 23,900 gallon 30' Round AG, Hayward 1HP 2-speed pump, Hayward 300# Sand Filter, Taylor K2006c.
    Lehigh Valley, PA
    Do you have ball valves on the plumbing between the pool and the pump? I do, and I turn them to the OFF position before opening the pot lid. That seems to relieve the vacuum pressure inside the pot -- the pump is OFF, of course, when I do that. You could also try sticking a pipe wrench through the handle and using it as a lever while pushing downward slightly so you don't dislodge the entire pump pot.
    May 2012
    Eastern North Carolina
    I'm no expert, but if you DON'T have a valve between the pool and the pump pot, and your pump is below the water line, it might not be such a hot idea to take the lid off. There's a lot of water pressing against that lid which might be why it's so tough to get off, and why it will be even harder to get on over your new geyser water feature.
    17,500 gallon 27' AG vinyl
    Hayward Powerflow LX 1.5hp pump with Dream Line sand filter
    Lehigh Valley, PA
    Yep, Mike, totally correct, but I can't even begin to tell you how many creative plumbing setups I've seen in photos with quite a few not having a way to shut off the water to/from an AGP.
    Aug 2011
    Massachusetts
    I ended up getting it open finally! I guess I was just stronger yesterday. I ended up stuffing a shammy down the skimmer hose to stop the water. It worked. I also found why it was so difficult to take off.... gasket was out of place.
    Lehigh Valley, PA
    What happened to the other posts in this thread? Have they been moved elsewhere?
    No, nothing moved. He actually posted pretty much the same thing in a different thread as well and that was probably the one you read. It is here: http://www.poolforum.com/pf2/showthr...ng-pump-basket)
  1. The pool is OPEN!
    By AnnaK in forum General Interest
    Last Post: 04-16-2012, 08:51 AM
  2. Now OPEN!
    By madwil in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-08-2011, 08:50 AM
  3. How NOT to open your pool
    By TimWillin2 in forum Dealing with Algae & Slime
    Last Post: 05-16-2008, 05:46 PM
  4. So...I forgot how to open! Help
    By jmjbj_h in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-21-2007, 02:09 PM
  5. Pool about to open...what do I do?
    By albertgarrido in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-22-2006, 10:49 AM
