Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 35 of 35
Thread: Automatic Liquid Bleach Dispenser
  1. #31
    Central Texas
    Default Re: Automatic Liquid Bleach Dispenser
    Not yet. I'd like to place the tank inside because of the high air temps here in the summer. But correspondence with the manufacturer indicates that it's not an airtight lid, nor is it set up to vent the tank to the outside.
    Tom Wood
    15K IG Plaster, Sand Filter, Polaris 180
  2. #32
    keithw is offline Registered+ Thread Analyst keithw 0
    I am going to rehash this old thread. Has anyone found an inexpensive, reliable way to automatically dispense small amounts of bleach into a pool? I have a 6000ish gal pool that I would estimate that I add about a cup of bleach a day to maintain. It would be nice if I could automate that process.
  3. #33
    Weird, I was just looking at this old thread too. I think I am going to give the Haas thing a try and see how it goes. Adding bleach all the time is a PITA and I don't want to go SWG, too much money. This seems like a good compromise.
  4. #34
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    There is a European patent for using a dishwasher rinse-aid dispenser as a chlorine (or bromine) dispenser. It's evidently designed to dump it's contents over many cycles, so it could be used to dispense bleach a bit at a time.
    http://www.freepatentsonline.com/EP1543763.html
  5. #35
    drumr is offline ** No working email address ** Thread Analyst drumr 0
    Gordonsville, Tn.
    I haven't gotten my little pump out of winter storage yet, but will probably this next week. Its just a small metering pump which works very well. When I set it back up I will take a picture. One hose goes it the bottle of bleach and the other in the skimmer, and set it as low as it will go.
    JD
  1. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
  2. Automatic chlorine dispenser??
    By roederrl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-10-2006, 05:39 PM
  3. How much salt does liquid bleach add?
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-06-2006, 07:56 PM
  4. Why not use liquid chorine instead of bleach ?
    By hancop in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-18-2006, 10:43 PM
  5. Pucks without CYA / Floating liquid chlorine dispenser
    By Gutbucket in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-16-2006, 09:13 PM
