Thread: Do I really need to brush the sides?
    May 2012
    Oklahoma
    Default Do I really need to brush the sides?
    As you can see below, I have a much smaller Intex pool than most of you (don't worry, I plan on going up to the next model each year as I get more comfortable with all this stuff), here is my question. I know it's not exactly a chemistry question, but it does relate heavily to chemistry......do I need to brush the sides of the "kiddie" pool every week or so? I do not have problems with the green stuff......my pool is occasionally cloudy and changing the filter usually takes care of that after a couple of hard Saturday and Sunday kiddie play days in the pool. I do use my triangle vacuum/brush for the floor which usually has some sand on it at the end of two days, but that's it. Are we assuming the kiddie pool has no filtration system in it?
    What makes me ask this question is that it is on the "Maintaining Kiddie Pool Chemistry" web page on poolsolutions website, it is recommended that the brush be used on floor and walls. That would make sense if I had problems with alot of organic stuff falling in the pool, but it's covered all the time it's not used. If I don't have any problems (that I am aware of), is brushing just good upkeep, like checking chemistry everyday? Considering the pool gets used hard on the weekend should I simply and quickly brush the sides just to ensure nothing grows there before I put it to bed on Sunday evening? I am afraid I need to be guided here.....not seeing why I need to do this if I have no problems.
    Bob E.
    Intex 10' x 30" metal frame pool, Intex 2500 gph filter/pump, Intex Saltwater generator, SwimMax 11KW heater, 2 x Small Game Solar Domes.
    BigDave's Avatar
    Default Re: Do I really need to brush the sides?
    When I had the Intex donut, I'd brush the sides whenever they started to get a little slippery.
    If you maintain the chemistry properly, you shouldn't feel slipperiness which is a sign of an impending algae bloom. To be honest, I don't brush my pool weekly but my chemistry is consistent. Plus, I vacuum several times a week and the vac head has brushes on the bottom so it kind of kills two chores at once.
  1. Legacy Portable w/ Bowed Sides
    By odddon in forum Above-Ground Pool Construction & Repair
    Last Post: 01-14-2016, 10:16 AM
  2. Hard or Soft Sides?
    By ktkauf in forum --cleanup--
    Last Post: 06-14-2013, 05:30 PM
  3. fiberglass pool reoccuring yellow sides
    By lorididrickson in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-25-2012, 06:49 PM
  4. sandpaper sides in newly opened pool
    By chich in forum Dealing with Alkalinity and Calcium
    Last Post: 06-17-2012, 08:36 PM
  5. agp bowing on sides after liner install
    By helpneeded in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2012, 11:32 PM
