When the filter is new and when/if you get air in from servicing it you need to bleed the air out.Originally Posted by expose
One way to tell if you have air in the filter is when the pump stops running - watch for a surge/burp of water back into the pool. If it occurs it may be because there is air trapped in the filter. The air gets compressed somewhat in the top of the filter by the water pressure so when the pump is turned off the air expands and pushes the water out.
It is alos dangerous to have this build up of air in the filter. You should run the pump and open the bleed until a steady stream of water comes out. Once the flow is steady close the bleed valve and your done.
