Thread: Low calcium
    Default Low calcium
    I have an Aquarite and calcium of 80 in a vinyl inground. Is that a problem? They recommend 200-400. Thanks
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    Default Re: Low calcium
    Welcome to the forum.
    It's 200 - 400ppm for a gunite pool. 120 ppm is Ok for a vinyl pool. You are Ok. Whoever recommended you did not know you had a vinyl pool.
    Hope this helps.
    Pat
    KurtV is offline Registered+ Widget Weaver KurtV 0
    Mandeville, LA, USA.
    Do you have a heater?
    Yes a Heat Siphon heat pump.
    Then you may want to run your calcium hardness a bit higher than 80 ppm. Even though you generally don't need calcium in a vinyl lined pool, it may help protect the heater.
    Ben's tip on calcium in vinyl pools alludes to this: http://www.poolsolutions.com/tips/tip03.html
    I knew it wouldn't hurt the pool.(found that info here) I am just worried about the SWG. Thank you for the help and welcome!
    Quote Originally Posted by PatL34
    Hope this helps.
    Pat
    Ft Lauderdale, Fl
    Low calcium will not harm a salt chlorine generator. However, low calcium contributes to a corrosive tendency of your water. You should also provide your total alkalinity and pH levels...and your water temperature.
    Corrosive tendencies will lead to erosion/corrosion of anything metallic in contact with the water...think ladders, light rings, heat exhangers (unless it's titanium), and handrails.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. calcium hypo vs. calcium chloride
    By Oclat in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2010, 05:06 PM
  2. Calcium = 650!
    By jman311 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-24-2006, 11:48 PM
  3. How much Calcium do I need?
    By grdnchik in forum Dealing with Alkalinity and Calcium
    Last Post: 09-20-2006, 02:05 PM
  4. How much calcium in calcium-based shock?
    By cleancloths in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2006, 04:58 PM
  5. Calcium and SWC's
    By jacthiele in forum Dealing with Alkalinity and Calcium
    Last Post: 05-24-2006, 01:53 AM
