I opened my pool a couple days ago and topped off the water. Here are my test results:
FC: 2.5
CC: 0, or very very low
TA: 50
pH: 7
CYA: 0
Can you all please help me get the chemistry setup right?
Eric
FC: 2.5
TA: 50
pH: 7
CYA: 0
Eric
Steel-sided, 7,186 gallon Above Ground Pool
Hayward 150 lb sand filter
Hayward Power-Flo LX Pump (1.5hp | 70 GPM)
Taylor K-2006 test kit
Other than your CYA, which we recommend for most folks to start out at about 40 ppm, your chemistry actually looks pretty good. Don't let the pH go below 7.0, and with 0 CYA in the water you'll need to add chlorine daily (maybe a couple of times daily) to make sure the Cl level doesn't get to zero. CC of zero is good.
How does your water look? What source of chlorine do you use?
My water is crystal clear, minus all the tree stuff that's been blown in there.
As far as a chlorine source, I use generic bleach from Wal-Mart.
Buy the smallest container of CYA that you can find. It may be called stabilizer or conditioner but if the ingredients say cyanuric acid or isocyanuric acid, it is the right stuff. You'll need about 2 lbs. for now. You can add it one of two ways. Either pour it slowly into the skimmer while the pump is running and leave your pump running 24/7 for the next 4 or 5 days while it is dissolving. Also, don't backwash during that time period or you'll blow the CYA right out and waste it. Or, you can put it into an old sock and hang it in front of a return jet. Give it a squeeze once in awhile to help it dissolve faster. This amount should get your CYA level to 35-40. If you decide later that you want it a little higher, you can always add more but if you overshoot now, there is no good way to get rid of it.
By the way -- you have a mighty big pump for that small pool!
