Thread: replacing booster pump.
    Default replacing booster pump.
    My polaris booster pump (polaris 280 cleaner) went out the end of last season. I plan on buying this pump and trying to install it myself. The price is so good I want to make sure this is the correct pump and comfirm that the switch should be easy.
    http://www.amazon.com/gp/product/B00...pf_rd_i=507846
    So it seems this pump is made by the same company that makes the pumps that come in the complete package.
    There should be the 2 water connections and 3 electric wires, that should be about it right?
    Default Re: replacing booster pump.
    Sounds like a good deal (depending on what the shipping is )
    You can also look into just replacing the motor, but I think that, for the price, a whole new pump is easier and not too much more expensive.
    You are right about the '2 ports and 3 wires' aspect.
  1. polaris booster pump
    By kimrob in forum Pool Cleaning: Manual or Automatic
    Last Post: 12-09-2012, 01:19 PM
  2. Polaris PB-4 Booster Pump
    By snj2k2se in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 02:03 PM
  3. Eliminate booster pump for cleaner with 2 speed pump?
    By breckens in forum Pool Equipment & Operations
    Last Post: 08-01-2007, 10:13 AM
  4. Too much booster pump
    By poolnewbie in forum Pool Cleaning: Manual or Automatic
    Last Post: 03-10-2007, 09:44 PM
  5. SWG and Booster Pump Tee Installation???
    By Sardian in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-18-2006, 09:27 PM
