Thread: Outdoor sound system for my pool
    Apr 2012
    High Point, NC
    Default Outdoor sound system for my pool
    Not sure if this is exactly where to post this since this is not exactly a pool equipment question, but it is about equipment for use around my pool. If this should go somewhere else, please move it to the appropriate place.
    Now that I have my pool running smoothly (thanks in large part to you guys), I am thinking about having a pool party and want to get some tunes flowing. Does anyone have any advice on good speakers / audio equipment for a pool with a wooden deck? I would prefer if it would interface with my PC, since I have tens of thousands on mp3s on my PC, but I have alot of those on my Droid phone, so if it excepts external inputs, I should be fine.
    Look forward to hearing your thoughts. Thanks in advance.
    13,500 gallon AGP. Sand Filter. Swimmax 11KW Electric Heater.
    Largo, Florida
    Default Re: Outdoor sound system for my pool
    I've got a regular cheapie "aiwa" stereo like this one http://moerema.tripod.com/goodies/in...stem_2?i=1&s=1
    I have a shed on one side of my house where the stereo its-self lives, and you can run speaker wires VERY long without much problem. The speakers are very damaged due to them not being waterproof and being outdoors, but otherwise the setup works. I use my Droid2 phone connected via the headphone jack to the stereo for streaming.
    If you have someplace dry you can put a stereo, you should be able to use pretty much anything. You should get outdoor speakers up front. When I do replace my decaying speakers, I'll probably use something along the lines of these: http://www.crutchfield.com/p_107ATR4...=N#details-tab although that site tends to be a little expensive so I'll probably actually order them elsewhere.
  1. Considering UV for a new outdoor pool.
    By Symon in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2013, 04:09 PM
  2. Private Outdoor Pool Surface Cleaning - Questionnaire
    By spnshlaura in forum --cleanup--
    Last Post: 10-30-2012, 08:22 AM
  3. Pool Heater Making Strange Sound
    By PhilB in forum Pool Equipment & Operations
    Last Post: 08-26-2010, 08:42 AM
  4. Indoor/Outdoor Carpeting around pool?
    By NWMNMom in forum General Interest
    Last Post: 06-18-2006, 11:18 AM
  5. New pool owner...this sound okay?
    By BillyBumbler in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 05:01 PM
