Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 49
Thread: greenish and cloudy
    Default Re: greenish and cloudy
    Is it still green?
    May 2012
    Florida
    I would say the pool is more cloudy then green. If you sweep it then green does appear to come off the vinyl and then the pool looks nasty. Buying the test you all recommended today. Sure I wont have it until next week because of shipping. I am going to use my Wal-mart test again this evening when I get home.
    18x36 3.5 - 8' depth, IG pool with SWCG; ~21K gal
    Add the bleach this evening, and then sweep AFTER you've done so; not before.
    May 2012
    Florida
    You got it PoolDoc. Thanks so much for your help. I will report back. Just signed up for the year. Looks like I will be here a long time.
    Thanks.
    Hopefully, if you're here a lot, it will be to help others. It shouldn't take that long to get a basic handle on what you need for your own pool!
  6. #16
    May 2012
    Florida
    Hi Ganny;
    Do this:
    1. Get a cheap OTO phenol red test kit from Walmart or wherever (explained on the test kit info page in my signature)
    2. While you're there, buy 12 gallons or so of PLAIN 6% household bleach - you can check for cheap liquid chlorine (10% bleach) often available in Florida later.
    3. Test your pool water in the EVENING
    4. Add 4 gallons of bleach after testing (about 12 ppm of chlorine, on your pool)
    5. Test in the morning
    6. In the evening test again, and then repeat 4 gallons if OTO is not DARK yellow
    7. Order a K-2006 (we need more info than the OTO kit can provide -- and so do you, if you want to escape the pool store!)
    8. Report everything, and we'll give you next steps.
    Pool Doc, When doing these steps, should I have my chlorinator and pump running?
  7. #17
    You definitely should have the pump running, but keep an eye on your filter pressure and clean the filter when you get to 8-10 psi over your "clean" pressure. The chlorine you put in the water will kill the algae, but it's the filter that removes the dead stuff from the pool.
    Last edited by aylad; 05-03-2012 at 03:24 PM. Reason: fix typos--I hate autocorrect!!
  8. #18
    May 2012
    Florida
    Filter pressure. LOL. I have so much to learn. And to think I have been running blind for 5 years.
  9. #19
    May 2012
    Florida
    OK, got a mouse out of the pool, poured in 4 gallons of bleach, swept real good, now waiting. I will check chlorine in the morning when i get up. Got my chlorinator at 50%, should i change this?
  1. Bluish/greenish particles
    By MRL325i in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2012, 06:17 PM
  2. greenish tint to water
    By daybaron in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2011, 10:32 PM
  3. greenish water
    By mikemedic in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2007, 08:10 PM
  4. Help-Cloudy Greenish Water
    By bacrocker in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-26-2006, 09:15 AM
