Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 49
Thread: greenish and cloudy
  1. #31
    May 2012
    Florida
    Default Re: greenish and cloudy
    Thanks Watermom. I dont have my good test im yet. All i can check is chl and ph. I did the 1/2 dilluted with tap water and it came out yellow. Slightly darker then the test had.
    18x36 3.5 - 8' depth, IG pool with SWCG; ~21K gal
  2. #32
    Quote Originally Posted by ganny76 View Post
    Pool is clear with no algae, but test is still orange. Is it safe for kids?
    It's safe for kids . . . but not expensive swim suits. You must have some stabilizer -- otherwise you'd lose all the chlorine in 1/2 day's sunshine, so it may not be a problem even for swimsuits.
    My older son swam for a month, 2 - 3 hours per day in a pool with zero stabilizer (indoors) and 20 - 30 ppm chlorine because their ORP controller was mis-calibrated. I finally had to threaten to call the health department to get them to fix it. It killed two of his swim suits, and turned his hair ash colored (from brown) but otherwise didn't hurt him.
    Last edited by Watermom; 05-06-2012 at 04:04 PM. Reason: change it to safe for "kids" rather than "kits"
  3. #33
    May 2012
    Florida
    Thanks again everyone!!!!
  4. #34
    May 2012
    Florida
    New problem, off subject, i had turned my swcg off while i did the bleach. Today when i turned the power back on, the display is now acting up. Doesnt show salt content or water temp. Shows a few things, but others are blank.
  5. #35
    First thing to try, with almost all electronics, is a full power cycle, as in kill the power to the power supply.
    If that doesn't work let us know exact make / model of your unit.
  6. #36
    May 2012
    Florida
    Might be where i screwed up. Instead of just turning it off i turned its breaker off. So it had no power supply. I did this several times when the screen was screwing up. Its an aquarite, but i will get exact model tomorrow, storming outside right now.
  7. #37
    May 2012
    Florida
    Oh yeah, it was about 93* outside and the kids and neighboring kids had a blast!!!! Thanks so much for all the help you all continue to give.
  9. #39
    May 2012
    Florida
    Maybe you will get to enjoy it soon enough. We have been swimming since the end of February. The water was cold, but we had 85* temps.
  1. Bluish/greenish particles
    By MRL325i in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2012, 05:17 PM
  2. greenish tint to water
    By daybaron in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2011, 09:32 PM
  3. greenish water
    By mikemedic in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2007, 07:10 PM
  4. Help-Cloudy Greenish Water
    By bacrocker in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-26-2006, 08:15 AM
