You can always hook up a regular water softener and run the pool water thru it. Works good, but does take a lot of time and effort, and does add salt to pool (not an issue if using SWG). My plaster pool was up to almost 800ppm of calcium hardness - took 2 weeks to drop to 200ppm using a Sears home water softener and a 1/2 hp submersible pump
