Thread: installing new deck and coping
    Dec 2011
    Default installing new deck and coping
    i had concrete deck around my pool. it was not that bad but every now and then it gave me issues like cracks or pieces coming out.. so i have decided to replace the concrete with interlocking (while doing the backyard patio) so the stones go all the way to the pool. now, the contractor could not save the coping stone while removing the concrete and now I have to replace the coping as well..
    what is the best option for the coping stone? take one from Unilock? they brought some samples but the concrete pool wall thickness is about 35 cm while the stones are 30 cm max.
    Jun 2011
    In the Sticks near Houston, TX
    Default Re: installing new deck and coping
    Subscribed.
    My deck is in bad shape too and I would like to fix it one day.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
  1. Replacing deck & coping on a vinyl liner pool
    By sampeterson18 in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2014, 11:22 PM
  2. To seal or not to seal: marble coping and deck
    By famousdavis in forum In-Ground Pool Construction and Repair
    Last Post: 07-26-2011, 02:43 PM
  3. Type of caulk between coping and deck?
    By billhev in forum In-Ground Pool Construction and Repair
    Last Post: 05-26-2008, 11:16 AM
  4. Installing a deck-mounted start rail
    By rbonin in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2006, 02:47 PM
  5. Caulk between deck and coping?
    By bhelme in forum In-Ground Pool Construction and Repair
    Last Post: 04-15-2006, 09:32 PM
