Testing Ph with high Cl' levels?
					How do you test Ph if the Cl' levels are 25ppm? CYA level is around 100 maybe a little higher. Raised Cl' up to 25 - 30 ppm to shock the algae. Ph was a little low before we started adding the 12.5% Cl. I did add borax before we added the Cl' to get it close to 7.2 range. Ran out of Borax.
I retested the CYA level with 50% pool water and 50% well water. Came up with 100 so that is about 200. I am not sure what level the CYA level is now.
This mornings numbers:
TA - 40
FC - 32 ppm
CC - 0
Ph - off scale low
CYA - ~200
I tested water again 6 hours later and FC levels have not changed. Originally I thought the CYA level was 100, that is why we tried to start to treat the water.
How much water needs to be drained and refilled to lower the CYA?
I came up with about 20,000 gallon pool with vinyl liner. 17' by 32' in-ground 3 foot shallow end to 8 foot deep end.
			~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
