Results 1 to 10 of 18
Thread: Anyone used "Zeosand" in place of regular sand?
    Default Re: Anyone used "Zeosand" in place of regular sand?
    I've been using Zeolite, and I do Add stuff through the skimmer, it has NEVER caused a problem.
    I do understand why you'd have to backwash on first use, the zeobrite/lite is a mineral and during transport it actually grinds against itself creating a fine powder, this powder needs to be eliminated and not blown into your pool.
    However, if it goes into your pool, just shut the pump off for a day or two, let it settle (even adding some floculant will help bind it with the rest of the foreign stuff), add some DE into the skimmer and vac it out - the DE will catch it and you can backwash it out.
    Benton, La
    No explanations other than that the zeolite is REAL temperamental about what goes through it & will need to be recharged (or something like that) more often.
    27ft. Round AG Pool
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Replies: 5
    Last Post: 02-22-2007, 03:18 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
