Results 11 to 18 of 18
Thread: Anyone used "Zeosand" in place of regular sand?
    Default Re: Anyone used "Zeosand" in place of regular sand?
    I've been using Zeolite, and I do Add stuff through the skimmer, it has NEVER caused a problem.
    I do understand why you'd have to backwash on first use, the zeobrite/lite is a mineral and during transport it actually grinds against itself creating a fine powder, this powder needs to be eliminated and not blown into your pool.
    However, if it goes into your pool, just shut the pump off for a day or two, let it settle (even adding some floculant will help bind it with the rest of the foreign stuff), add some DE into the skimmer and vac it out - the DE will catch it and you can backwash it out.
    Benton, La
    No explanations other than that the zeolite is REAL temperamental about what goes through it & will need to be recharged (or something like that) more often.
    27ft. Round AG Pool
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    I saw this on an Internet site advertising Zeosand.
    >>Can the chloramine control be renewed? Yes. Like any water softening resin, the ZeoSand ammonium trapping can be renewed with a saltwater rinse. Drain the filter, fill with a 10% salt solution, and let stand for at least two hours. Then, backwash to waste.<<
    So, does this mean that Zeosand performs differently with a Salt Generator system than a clorine system? Salt would be run through the system at every backwash. I know it is not 10% salt, but it seems like frequent backwashes would have the same effect.
    Beary
    simsjim is offline Registered+ Thread Analyst simsjim 0
    Jul 2006
    Quick question. Do you think that its okay to mix Zeosand and regular pool filter sand?
    Quote Originally Posted by simsjim View Post
    I wouldn't. You'll probably gain the disadvantages of both.
    anyone useing Zeosand mixed with regular sand? is that ok? good/bad? thanks
  7. #17
    I wouldn't mix the two--as Carl said, you'll likely get the disadvantages of both. I switched to zeosand in the middle of last year and frankly I think it does a better job (although it's harder to get out of the pool than regular sand)
    Sherwood, Arkansas, USA.
    Been using it for over a year now and the pool is clearer than ever. I would recommend it.
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 10:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 08:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 11:28 AM
  4. Replies: 5
    Last Post: 02-22-2007, 02:18 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 10:34 PM
