Thread: Filtration / Run Time...
    mas985's Avatar
    Pleasanton, CA
    Default Re: Filtration / Run Time...
    I would think that the largest consumer of chlorine in a private pool would be the sun and therefore, it should be more important to both chlorinate and circulate the water while the sun is striking the water. Any run time beyond that could be split up but off hours where no one is swimming and the sun is not shinning should not consume as much chlorine and therefore not require as much circulation.
    During the summer, I usually run the pump about 8 hours mostly on low speed but I target the heat of the day and into dusk so chlorine levels stay relatively constant during the day and through the night even though the pump does not run at night. However, whenever there is night time swimming, I will manually turn on the pump until everyone is out of the pool.
    Mark
    Apr 2012
    Los Vegas
    ... I usually run mine in one stretch. It's on a timer from about 11am to about 8pm once the season gets going.
    Quote Originally Posted by mas985 View Post
    I've read here that one should add liquid chlorine at night, when the sunshine will not impact available FC. How long should one run the pump to circulate the newly-added liquid chlorine? Do you factor that run time into your daily run time? (sorry if the question seems very basic; I'm new here...)
    7500G IG fiberglass/175 sq ft cartridge filter/1.5HP pump
    Actually, we need a how and when to run page . . . and I hadn't realized that before. There are too many issues, and several have come up today.
    For your specific question, the pump should probably run 1/2 hour after adding any chemicals, and probably longer if you added any sort of granular materials to the pool.
  1. Intex filtration problems
    By teamwir in forum Intex-type Pool Setup & Operations
    Last Post: 06-20-2013, 04:04 PM
  2. pool filtration
    By ladypoolfool in forum Pool Equipment & Operations
    Last Post: 06-14-2013, 04:43 PM
  3. UV Pool Water Filtration
    By Pibster in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-25-2012, 01:18 PM
  4. No filtration yet but here are the numbers
    By csevel in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-05-2007, 08:47 PM
