will do, thanks!
Test as often as you can and bring the FC back up if it drops below 15.
will do, thanks!
16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
Did you add bleach after you tested last night? How did your FC go from 16 to 18.5 overnight?
No, I didn't add bleach after last night's test so I don't know how or why FC went up. Tester error? I am trying very hard to test accurately. Summary of today's test results: 6:30 am, FC = 18.5 and CC <.5 11:30 am FC = 17.5 and CC = 0 3:00 pm FC = 14 so I added 96 oz. of bleach 6:30 pm FC = 18.5
Next steps?
thanks
Just keep doing what you're doing, until you're not losing any chlorine overnight. Then you can let the chlorine drift down to the normal range for your CYA.
FC = 18.5 this morning, same as late yesterday afternoon. So, no more bleach unless 1 of you experts tells me otherwise. When do I increase CYA to get it between 70 and 80 as recommended?
I just had a thought. Is you SWCG running? (this is not a prank call)
Yes.
OK, that could explain how FC went from 16 to 18.5 without adding bleach.
Can you shutdown SWCG without shutting down pump / filter? If yes, please do.
How's the water look, has the cloudy cleared? Running pump / filter 24/7? How's the filter pressure?
Please test FC, CC, and pH add bleach if FC is below 15 and get a FC reading at dusk so we can see how we're doing at dawn.
I have shut SWG down. Pump/filter has been running 24/7 except about 2 hours today when I ran robotic pool cleaner. Filter pressure has remained constant since 4/1/12 tho I backwashed late this afternoon. The water is not cloudy and there are no visible signs of dead algae. I brushed and saw nada. I wouldn't say the water is sparkling but definitely is clear. I guess I would describe it as a dull clear. Test numbers at 5pm with sun behind the trees: FC = 15.5, CC = 0 and pH = 7.3 to 7.4. I have not added any bleach today.
So, I should test FC, CC and pH at dawn? I have to leave my house about 6:20 in the morning and will be gone all day. Could you give me recommendations for the morning. I'll test and proceed per your guidance.
Thanks!
