Results 1 to 10 of 11
Thread: I have the "pinks" (instead of the blues!).
    Default Re: I have the "pinks" (instead of the blues!).
    Good that it was only a 1ppm drop in chlorine overnight. A CYA of 50 is good. It is not a precise test so hard to hit a target exactly. You are correct to wait until the chlorine drops some to test and adjust pH and alk.
    onemsmom is offline PF Supporter Thread Analyst onemsmom 0
    Aug 2010
    Following up: Tested today and here are the results:
    Chlorine: 7ppm
    pH: 7.4
    Alk: turned barely pink at 210, very pink at 220
    CYA: barely above the 40 line, but I will retest in a couple of days - just added stabilzer on Sunday
    Should I adjust pH up a bit? If so, how? I've never had to adjust it up before - I usually have the opposite problem. Is the Alk a little high? If so, when I add the muriatic acid, I guess that would mess with the pH too - pushing it down, right? Then I should bubble the pool?
    Please advise. I'm on such a good track - I really want to get it right.
    Thanks!
    Jenn
    Add your acid til the pH is 7.0, and the alk will also drop. Then aerate the water, and the Ph will come back up without raising alk. That way you can ratchet the. TA downward. Otherwise, a pH of 7.4 is fine.
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Green pool "blues"
    By George in Georgia in forum Dealing with Algae & Slime
    Last Post: 06-30-2010, 03:51 PM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
