Thread: raising alk?
    Dec 2005
    Weskan, Kansas
    Default What happens if I leave my alk 240?
    Thanks for all your help. What are the consequences of leaving my alk at 240. As I understand it, it will help my pH stay steady but there must be other issues. I'm new to this pool stuff but this site is a great way to learn and all of you are great help and I appreciate all your input.
    Thanks,
    Dave
    PS my numbers as of today
    fc 3.5
    cc 0
    tc 3.5
    alk 240
    cal 170
    cya 30
    ph 7.5
    temp 64
    water only slightly cloudy but I can easily see the bottom and pattern on the liner of my 30' round AG
    Default Re: raising alk?
    Hi Dave,
    I just joined the forum yesterday and am still learning, but am working on a similar issue. My understanding is that if you have a heater or plaster (or both), you want to keep your Alk in the 80-120 range because scaling happens at higher levels. I believe the range is higher for vinyl pools, but I have plaster, so I didn't commit that to memory. Check out the "How to Lower your Alkalinity" sticky--it's very helpful.
  1. Raising PH
    By adayray in forum --cleanup--
    Last Post: 06-29-2013, 09:00 PM
  2. Raising pH level wihout raising Alkalinity
    By JMannWV in forum Dealing with Alkalinity and Calcium
    Last Post: 08-01-2012, 12:28 AM
  3. raising alk
    By CanuckPool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 10-10-2006, 09:56 PM
  4. Raising PH
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-08-2006, 12:50 PM
  5. Help with raising ph
    By ccc in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-15-2006, 05:42 PM
